Re: cloudy water
I added another gallon of bleach before bed. This mornings readings were:
FC 23.5
CC 0
PH >8
Is the off the charts pH due to the high chlorine? And is it really that high right now, or is it a false high? Do I need to worry about the ph then while I'm shocking if it's a false reading? Based on the chlorine chart, my shock level should be above 20. Since this morning it is only slightly above 20, should I add another gallon to carry it through the day and then take a reading tonight/tomorrow morning to see if everything is ok? If I add the gallon this morning, will it be circulated enough to do the test this evening/tomorrow morning or will it still be rising during the night? Thank you for your help.
