Thread: Hayward super pump issue
    Jun 2013
    USA
    Default Hayward super pump issue
    Pump would just hum loudly without pumping water.
    Took off the back cover the rotor was not turning but was free.
    So I looked at these forums and got a new capacitor.
    With the new capacitor the unit turned on but seemed weak (much quieter hum). The rotor spins and pumps water, but at a weak pressure, then the pump shuts off after 20 seconds.
    What do you guys think I should do next.
    Jun 2013
    USA
    Default Re: Hayward super pump issue
    anything?
    I'm sorry I can't really help -- of all the pumps I've repaired in 25+ years, I've had to get into deal with capacitors and internal switches only twice! There are a few guys here who've done some of that, but they're not real active right now.
    You might try posting at poolspaforum.com -- they have a lot of pool industry members there. Just watch out for their advice on pool chemistry -- most of them hang pretty close to the pool chemical manufacturer's version of things.
    However, one member at poolspaforum.com is on our support team -- username Waterbear. His advice you can trust.
    mas985's Avatar
    Pleasanton, CA
    The bearings are probably bad causing the motor to overload and trip the thermal limiter switch. Bearings can be replaced if you have a puller or you can replace the whole motor.
    Mark
    Thanks, Mark.
  1. hayward super pump
    By lnjwink in forum Pool Equipment & Operations
    Last Post: 06-11-2012, 03:06 PM
  2. Hayward Super Pump is Super Noisy
    By moneypitpool in forum In-Ground Pool Construction and Repair
    Last Post: 07-25-2011, 10:16 AM
  3. Hayward Super Pump - Super Hot and Shutting Off
    By CapitalBoo in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 09:32 AM
  4. Hayward Super Pump Really Hot...HELP?
    By calamtykel in forum Pool Equipment & Operations
    Last Post: 06-14-2009, 04:30 PM
