Thread: Using 2006 pool and spa water chemistry book
    May 2013
    Concord,ca
    Default Using 2006 pool and spa water chemistry book
    I am going by my k-2006 booklet before I add anything? yes ? no? I was using it as a guide. Should I use it as a pool Bible
    BigDave's Avatar
    Default Re: Using 2006 pool and spa water chemistry book
    The book that came with the K-2006 is pretty useless - completely useless when it comes to chlorine targets. Take your chemistry advice here.
    May 2013
    Concord,ca
    10-4 and how do I get my size of pool filter etc etc at the end of a question? Thanks, Dave Gale
    Dansdad,
    I think you are talking about making a signature that shows up at the bottom of each of your posts? Go to settings (near the upper right where you log in). Then, on the left side, click create signature. I think that is how you do it. Haven't done it in awhile. Give it a try and lets see if that works.
    May 2013
    Concord,ca
    just did that Watermom thank you
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    I see it! Thanks for doing it. It makes it a lot easier on all of us to help when we can see your pool's specs at the bottom of the post instead of us having to hunt for it.
    Edit your signature and add to it that you have a K-2006. That is helpful for us to know as well.
    Thanks!
  1. Pool Water Chemistry (Warning: Can Get Technical)
    By chem geek in forum The China Shop
    Last Post: 06-02-2007, 03:28 PM
  2. New Pool owner water chemistry
    By sammm in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-11-2007, 09:56 AM
  3. Device for Monitoring Pool Water Chemistry
    By CJDahl in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-05-2006, 03:44 PM
  4. Pool is done, water chemistry is getting there too....
    By GTakacs in forum DPD-FAS based testing
    Last Post: 07-18-2006, 11:52 AM
  5. Water Temp & Pool Chemistry
    By cheshamjim in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-23-2006, 03:55 PM
