Results 1 to 10 of 13
Thread: Advice on Variable Speed Pumps for Spa
    Sep 2011
    Default Advice on Variable Speed Pumps for Spa
    I have a 2HP single speed motor/pump now and plan on replacing it with a 3HP variable speed. I like the Pentair IntelliFlo VS. Input would be appreciated. Thanks.
    Sep 2011
    Default Re: Advice on Variable Speed Pumps Please
    It is only 2,500 gallons but it has 16 jets. It is a large in ground spa. The main reason I want the variable speed is so I can run it longer during times of non use.
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by JohnASmith View Post
    A cheaper option would be to replace your current pump motor with a two speed motor. A two speed pump would allow to run on low speed at off times and it would save quite a bit in energy costs. A VS is really overkill for your situation but if that is the way you want to go, an Intelliflo is a good choice, albeit an expensive choice.
    Mark
    Sep 2011
    I thought of a 2 speed but it would really need to be 2HP high and 1/2HP low to do what I want and I don't think they make them that way. I also thought of paralleling a second pump with back check valves running only the one needed. Space is a bit tight for that but maybe possible.
    mas985's Avatar
    Pleasanton, CA
    HP motor ratings don't tell you much about the performance of a pump. I can show you a 1/2 HP pump that produces more flow rate than a 2 HP pump on the same plumbing. So why do you think a 1/2 HP is the right "size"?
    FYI, with a two speed pump, low speed will have about 1/2 the flow rate of high speed but only at 1/4th the wattage.
    Mark
  1. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  2. Variable-speed pumps: US Dept of Energy guide (May 2012)
    Last Post: 07-24-2012, 05:04 PM
  3. UGH! Variable speed? Which one?
    By awhite6455 in forum Pool Equipment & Operations
    Last Post: 06-09-2012, 09:01 PM
  4. I;m looking for information on variable speed pool pumps
    By kearneypd in forum Pool Equipment & Operations
    Last Post: 04-19-2012, 08:54 PM
  5. Dual Speed or a Variable Speed for a plain Jane pool.
    By Lip Out in forum Pool Equipment & Operations
    Last Post: 03-14-2012, 10:32 PM
