Results 1 to 10 of 13
Thread: Advice on Variable Speed Pumps for Spa
    mas985's Avatar
    Pleasanton, CA
    Default Re: Advice on Variable Speed Pumps Please
    The 011017 is an SVRS which may or may not be required depending on local codes and how your suction side plumbing is designed. Pentair is a good brand and most people are satisfied with it. However, there have been a few where the drive has failed and the repair costs are more than a new pump. Just make sure you use lightning/surge protection on the circuit that drives the pump.
    But again, for what you are planning to do, a 2 speed motor for ~$300 pump will accomplish the same thing.
    Also keep in mind too, that you really don't need to run a pump for long periods of time to keep a pool clean. There have been studies which have shown that most pools (and large spas too), can get by with less than 4 hours of run time per day with no noticeable difference in water quality.
    You seem set on the VS and that's fine. I just want to make sure you understand all the facts before making that decision. There are a lot of myths going around the industry and one of the biggest myths is that VS saves much more in energy costs than a 2 speed which is simply not true. The difference in cost savings is minimal and is rarely enough to justify the extra cost of the VS pump.
    Mark
    Sep 2011
    I would think that my 2HP pump is moving at least 100 GPM which means a complete cycle in 25 minutes. I know that is actually conservative because I can drain it empty in far less that 25 minutes, more like 15 minutes.
    BigDave's Avatar
    One note: I purchased the SVRS version of the Hayward ECOStar and had to ask Hayward - very nicely - for a downgrade to the non-SVRS controller because the SVRS pump saw priming my roof mounted solar panels as an entrapment event and shutdown.
    Sep 2011
    Big Dave, I too have roof mounted solar. I am having trouble understanding how that could effect the controller in a variable speed pump, can you expand on that? Thanks.
    BigDave's Avatar
    My solar system has a valve (vacuum check?) that lets air in the system to allow the panels and piping to drain back down when not in use. Because of this the panels need to primed each time the controller moves the diverter valve sending the pool water to the panels. While the pipes and panels are filling, the flow rate slows significantly because the pump is overcoming the static head as well as the dynamic head in the piping system. Once the pipes, panels, and return lines are filled, the static head is equalized by the weight of the water in the pipes coming down from the roof.
    The SVRS (Safety Vacuum Release System) function saw this low flow to be an entrapment event (somebody stuck in the drain) and shut the pump down to release the suction.
    Sep 2011
