Thread: CYA test and how often
    Question CYA test and how often
    Question-
    how often do you test CYA and does it change quite often or does that depend on things like rain and such?
    I posted my results earlier and my CYA was the 30-50 range with the walmart test strip.
    thanks
    IL.
    Default Re: CYA test and how often
    Once CYA is in the water, it is only lost from splash out or drainage, like when you backwash, etc.
    No need to continually test it unless you experience one of those situations or you use a chlorine product that adds it, like di or tri-chlor.
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
