Re: 1 extra slat in my wall
Ugh! It took me 6 hours to remove the one slat in the deep end. I had to dig out the compacted top soil in order to shorten the radius. And on the shallow end, the foam is not wall foam it’s 1” foam on the pool bottom. This is what I want to do….
Since this is a hopper bottom liner, it may not be made specifically for this pool (they gave me a dig sheet). I will snap it into the liner track and if it comes up short, I will remove it and then take 1 slat out of the shallow end curved side. If it seems to fit without stretching, I keep it as is. The walls right now do not have the top ledges on and no water in it and it feels extremely sturdy and that’s because for this pool when I dug the deep end the instructions said I need an 1.5’w x2’d x 10’L concrete trench on each straight side and secure the main beams to it with anchor bolts.
