Thread: Ground or Sand Have to be Level Under an Intex Pool?
    Jun 2013
    Kentucky, USA
    Default Ground or Sand Have to be Level Under an Intex Pool?
    Stupid question I'm sure... but here goes.
    Installing a used AG and wondering if the ground has to be exactly level first (it is almost level), or if the sand can make up the difference.
    IOW, do I have to level both the ground and the sand, or just the sand? Thanks for the help
    Default Re: Ground or Sand Have to be Level?
    One of the most common reasons we see for Intex pool failures is un-level ground. It's quite important to get the pool very level -- not more than 1 - 2" out of level from side to side.
    Sand is a problem. It tends to shift and move, and when you use sand to level under the pool, your pool becomes un-level when the sand shifts. Small amounts of sand, to filling small holes or divots is probably OK. Otherwise, it's not the ideal material for leveling a pool area.
  1. Intex Ultraframe 12x24 How Level is Level?
    By DMDPT in forum Intex-type Pool Setup & Operations
    Last Post: 07-29-2012, 03:20 AM
  2. Using sand to level an area for an Intex Metal Frame 15 x 48 pool
    By RedwingT in forum Intex-type Pool Setup & Operations
    Last Post: 07-13-2012, 10:29 PM
  3. Intex Above ground, G.A.M.E Sand Filter, BioGuard Stingy Sticks, and other chemicals
    By kristen in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-17-2011, 04:22 PM
  4. Intex AG pool skimmer water level?
    By aylad in forum Above-Ground Pool Construction & Repair
    Last Post: 03-03-2011, 09:58 AM
