Thread: First pool test!
    Jun 2013
    usa
    Default Re: First pool test!
    I am new also. My test are almost the same as yours and my pool is still crystal clear after a week
    You can ignore the bromine side of your tester since this is a chlorine pool.
    It would be good if you had a kit that could measure your levels more accurately. A range of 5-10 on the chlorine is pretty vague. We recommend the Taylor K-2006 or 2006C which you can find in the test kit link in my signature below.
    Did you mean alk of 140 instead of 14?
    If your CYA test never turned cloudy, it means your CYA is less than 30 which cannot be detected.
    Jun 2013
    Missouri
    Yes, you're right, 140 not 14, same with hardness, should be 190.
    Is that bad having the CYA that low?
    Not bad, but it just makes it hard to keep chlorine in the pool especially on hot sunny days. If you continue to follow the startup 'recipe,' your CYA will gradually come up because the dichlor has CYA in it.
