You can ignore the bromine side of your tester since this is a chlorine pool.
It would be good if you had a kit that could measure your levels more accurately. A range of 5-10 on the chlorine is pretty vague. We recommend the Taylor K-2006 or 2006C which you can find in the test kit link in my signature below.
Did you mean alk of 140 instead of 14?
If your CYA test never turned cloudy, it means your CYA is less than 30 which cannot be detected.
