We have a 32' round above ground swimming pool which was installed about seven years ago. I changed out the original filter with a Haywood Power-Flo Matrix Pump and the Pro Series Top Mount Filter (S210T - 44gpm). I'm satisfied with the performance of the pump and filter combo. However, when I installed the system, Zeobrite was all the rage. It's been about four years now. I haven't had too many issues so far, until this season. We had a few top rails replaced and the technician commented on the water being somewhat hazy/cloudy. He asked what filter media was being used and I mentioned the Zeobrite. He advised to replace it with the regular filter sand. We brought a sample of water to the place where we buy the chemicals and they tested it. One thing that they found was that the total chlorine level was .5 and free chlorine was .5, as well. They indicated this to be very low (if I understood correctly). The evening before the water test, I added six bags (6 lbs) of shock and six sticks to the skimmer. The water in the other categories fell within the normal ranges. The problem is that the water went from hazy/cloudy to so cloudy you can no longer see the bottom of the pool which is only about 52" deep. The place where I test the water has stopped selling Zeobrite altogether since they we getting too many complaints. After researching the issue on the Internet, I found that not all, but many people are experiencing problems with this media. Cloudy water conditions, fine light colored dirt that accumulates on the pool bottom not long after it's been vacuumed, etc... I read also that algaecides and clarifiers can have negative effects with the Zeobrite. The weather is starting to warm up now and no matter how much I backwash the filter, it seems like there is no improvement. I've already used way more shock this season as compared to previous ones. I guess my question is, am I better off having the Zeobrite replaced with regular filter sand? Any advice would be appreciated.
