Thread: slat wall liner install
    Mar 2011
    PA, USA
    Default slat wall liner install
    Can i use that shop vac technique to suck out wrinkels on a slat wall pool, or do the slat joints allow too much air in to be effective?
    Mar 2011
    PA, USA
    Default Re: slat wall liner install
    I bought the shop vac and it did suck out the wrinkles in a slat wall pool. I did not have to tape up the 200 or so slat joints. It actually sucked some of the wrinkles out of the deep end too. The suction on this vac was rated 10, they ranged from 6 to 10 at home Depot.
  1. 1 extra slat in my wall
    By roto23 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-02-2013, 10:42 AM
  2. Proper way to install liner over top of wall
    By shovelrog in forum Above-Ground Pool Construction & Repair
    Last Post: 06-06-2013, 07:10 PM
  3. Foam Wall Liner won't stay attached to pool wall
    By pdxpool in forum Above-Ground Pool Construction & Repair
    Last Post: 07-02-2012, 04:24 PM
  4. Liner Install
    By mohawk in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2009, 12:27 AM
  5. AG Liner Install
    By snapperbig in forum Above-Ground Pool Construction & Repair
    Last Post: 05-18-2007, 02:50 PM
