Results 11 to 12 of 12
Thread: new to the forum
    Default Re: new to the forum
    Borax won't increase the TA. If you use soda ash, it will increase pH and alk but Borax won't. That is why we recommend using it to raise pH instead of soda ash.
    You can try and aerate to bring the pH up or you could add a little Borax. I'd probably do a couple of cups to start with. Then, wait a few hours and retest and redose as needed til you get the pH where you want it.
    May 2013
    Northwest Indiana
    Oops. I stand corrected.
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
