Thread: Full refill ballpark chemical amounts
    Jul 2013
    NY
    Default Re: Full refill ballpark chemical amounts
    Thanks, Watermom. That's a handy calculator.
    Do I stabilize first, or chlorinate, or can I do them at the same time?
    Is there a particular method for stabilizing? I used to just make a slurry and pour it in the skimmer, but I want to get started right. I used to notice that some of the stabilizer would remain un-dissolved on the bottom for a while.
    Thanks for the help!
    David
    You can do both.
    To add stabilizer (CYA), you can either put it in an old sock and hang it in front of a return jet and give it a squeeze once in awhile to help it dissolve faster or pour it slowly into the skimmer and let it dissolve in the filter. (That is what I do.) If you do put it into the skimmer, keep your pump running 24/7 for the next 4 or 5 days. Don't rerun the CYA test for a week after you add it so you will make sure it is dissolved. Don't want to waste your testing reagents.
    Jul 2013
    NY
    Thanks! I can't wait to get my K-2006 to do a thorough check. Who thought pool chemistry was so exciting!
    David
    You might want to look at the SS recipe for small pools; trying to hit exact doses does not work as well for most people as the 'add some, test, & add some more' approach.
    membership updated.
