Results 1 to 10 of 17
Thread: Green tinted water - Intex 15' X 48" Salt water system
    Jul 2013
    Massachusetts
    Default Green tinted water - Intex 15' X 48" Salt water system
    Hi,
    We have an Intex pool (15' X 48")that we put up and take down every year and we fill it with well water. The pool uses a salt water system. All previous years we have had no problem, and the water has been crystal clear, but this year after running the chlorinator for only an hour, the pool water took on a strong yellow tint. It is still clear, but tinted.
    I have since gone to a pool store for help and they had me add Keetrol Plus because they thought it was metals in the water reacting to the chlorine causing the tint. They had me add 12 oz originally, and I have since added another 10 oz. The color is now lighter, but is more of a green tint. The store also had me add about 2 1/2 pounds of Clear View to raise the total alkalinity.
    It is now several days later and the green tint is still present. I have also been running the chlorinator to make sure I dont start getting organic problems.
    I went out and bought a testing kit today (hth 6-way) and did some tests. I am hoping that if I post the results here along with the history, someone can tell me what is going on and what I should do next.
    Total Chlorine / Total Bromine - I could not tell. The water color turned orange and the max value of 5/10 is a dark yellow. I assume my level is way higher than that (which is surprising...no chlorine smell or anything to the water).
    Ph - 8.2
    Total Alkalinity - 100 ppm
    Hardness - 80 ppm
    CYA - 30 ppm is the lowest the test can measure...I think I am lower than that, but close (the black dot on bottom of tube was still visable, but barely).
    Please let me know if you need any further information or have any suggestions. Any help is greatly appreciated.
    Default Re: Green tinted water - Intex 15' X 48" Salt water system
    You should order a good kit. The one we recommend is the Taylor K-2006 or 2006C (test kit link in my signature below.) For now, get some distilled water and test your chlorine again using half pool water and half distilled water. Then, multiply your result by 2. Post the reading here.
    You cannot trust that pH reading. A pH reading taken when chlorine is really high is typically reads higher than it really is. Wait until the chlorine level drops below 5 and then test pH again and report it here.
    What kind of tabs are you using. Some tabs have copper in them and you do NOT want copper in your water!
    Go to the section of the forum called "Dealing with Stains & Metals." There is a stickied thread called "Bucket Test for Metals" at the top of that section. Read it, do a bucket test on your well water and report your findings here.
    Welcome to the Pool Forum, by the way!
    Jul 2013
    Massachusetts
    I did the test with 1/2 distilled water and 1/2 pool water and while the color was not orange, it was still a dark yellow and beyond the scale. I then repeated the test with 1/3 pool water and 2/3 distilled and it was still a darker yellow (but not by too much) than the top of the scale. Since the highest it can measure is 5 ppm, this would mean I have at least 15 ppm (5 x 3) and probably more like 20 ppm?
    I will read up on the bucket test and let you know my findings. I will also order one of the suggested testing kits.
    Not sure what you mean by what kind of tabs that I am using? Chlorine tabs? I dont put any Cholorine in the pool (other than what is generated by the chlorinator). I have never needed to do a shock or anything.
    OK. When you say chlorinator, you are referring to an SWCG (Salt Water Chlorine Generator) and not a chlorinator that you put chlorine tabs in. Gotcha.
    Jul 2013
    Massachusetts
    Yes, I use a SWCG system, sorry about the confusion. I am also not able to access the 'Dealing with stains & metals' section, so I can not read up on the bucket test yet.
    Until new members have their memberships upgraded, it is always necessary to log out first in order to see the rest of the forum. (Sorry I forgot to tell you that part when I wrote the post above.)
    Jul 2013
    Massachusetts
    K-2006 kit ordered (used the amazon link from the forum). I have also started the bucket test.
    Initial results -
    Well Water is clear with slight blue tint
    Pool Water is slightly murky with yellow tint
    After adding bleach and waiting 15 minutes I saw no noticeable change in color or clarity.
    I then added the Borax and will check them again in 24 hours.
    The other thing that is happening is that I have now changed the filter twice in a few days and both times the water in the filter chamber was quite brown and the filters themselves had picked up quite a bit of brown material, so there is clearly some minerals or something in the water. My SWCG system is 6 or 7 years old now...is it possible that there is corrosion inside the system and is the source of the minerals? The pool water was fine until I first turned the system on (both pump and chlorinator).
    Quote Originally Posted by Xevious2001 View Post
    It's iron.
    There are apparently some low-grades of salt that contain quite a bit of iron, being sold to pool owners for pool use. If there's not iron in your well water, then I'd check the salt out as a source.
    Membership updated.
    Jul 2013
    Massachusetts
    After 24 hours -
    Well Water - Clear, slight blue tint as before (which I believe is just normal water color in a white bucket). I did notice 2 very small deposits of some material on bottom of bucket.
    Pool Water - Clear, yellow tint but perhaps lighter than yesterday. Also noticed 2 small deposits of some material on bottom of bucket.
    The salt I used is Morton Pool Salt which (they claim) is free of additives and impurities. It is also the salt I used in previous years with no issues.
    The pool itself remains tinted..now seems more yellow than green. Water is still clear.
    Should I just drain the pool and get ready to start over? Or is there some way to recover from this. My wife and kids dont want anything to do with the pool (and who can blame them).
    I wouldn't drain the pool, but I would let the chlorine drop. OTO 'orange' can be 20 - 40 ppm of chlorine. If your stabilizer is truly < 30 ppm, that is very high. You should read the "Best Guess" page, linked in my signature, so you can understand more.
    Do this:
    1. Test your CYA with the K2006 as soon as possible.
    2. Operate your filter as much as possible --iron has to be removed as particles, either by vacuuming or filtering. Filtering is easier.
    3. The green water is dissolved iron -- you can't remove it in that state.
    4. Do not use any more "Clear View" (baking soda -- really!), Kee Trol or other pool chemicals, except chlorine and pH adjustment chemicals.
    5. The fact that the bucket test is only showing small amounts of iron (reddish material?) is good - that means you should be able to manage your pool fairly easily, once you get the hang of it.
    6. From now own ONLY fill via the skimmer or suction intake, and fill as slowly as possible. This will maximize the iron removed on the first pass.
    7. Turn the salt system down, or off. Your chlorine is too high. Unless your CYA is > 100 ppm, OR you are having severe algae problems, you should stay out of the "orange" range.
    8. Your family can swim, but wear old swimsuits. Skin is VERY chlorine resistant, far more than most swimsuits.
    One scary thought: a cheaply made SWCG (like the Intex) could add iron to the water, at least in theory. It's only a guess, but it's one I'll have to check into.
