Re: Green tinted water - Intex 15' X 48" Salt water system
Ok. I will do a full set of tests and the diluted pH test (I already have some distilled water at home).
Not sure if you missed it in my previous post, but I did a chlorine test last night using the hth 6-way kit and the chlorine levels have come way down (3 days of nothing added to pool + lots of sunlight). The reading was 2 - 3 ppm. Just wanted to make sure you were aware of that just in case it changes how you want me to run the test.
Reason: enable signature
4.3K gal 15' x 4' Intex AG pool; well water; PF 28
