33' Round above ground pool liner pulling out of bead
We have a 33' round above ground pool and when we opened it the liner (beaded liner) had pulled away from several spots. My husband emptied all of the water, totally cleaned it out and corrected the liner and reinstalled where needed and then began to refill the pool. 24 hours later he went to go out and check on it after church and in ONE spot above the skimmer it pulled away again! Now with it filled up to our knees and it's pulling the side in with it as it pulls away and causing wrinkles in the liner in the bottom of the pool. Any tips or tricks in fixing this? Do we really have to completely empty the pool AGAIN and start over?! HELP.. I have 8 kids needing to swim their energy out!
