Re: King Technology Pool Frog system AND green pool *Update*
pH has dropped to 7.2 from high of 7.5. Is this fluctuation normal? I thought that by adding chlorine pH would increase?
Do specific trees make the pool more acidic? In the garden I use Oak leaves to make the soil more acidic. Oak tree shadows the pool in the AM.
I am still cloudy, but water is blue.
POP is still low. I opened pool to family. Waiting on K2006 test kit to arrive. I want to test CYA so I know how high I can run FC. I am on the slow and steady program to prevent copper staining. How long does this slow and steady last? Copper be D&mned! We want clarity!
Called pool store to see if I could get a test to monitor FC at levels of 10-15 ppm so I could shock (POP is .03ppm) and maintain levels for 3-5 days to finally get to clear. Pool store person told me that
1) You will burn the liner!
2) You have phosphates!
Both of which I know to not be true based on the info I learned about here. Hooray Science & Thanks PF crew.
I imagine any issues I will have with the liner are due to not keeping the pH above 6.8 (which is where it was when I opened).
ALSO Wife said she was impressed that the water looks as nice as it does considering that in some years the water never looked as good as it does now.
18k gal AG 27' with 5-1/2' deep end, Hayward XStream 1500 Cartridge filter; Hayward 1.5 hp Power Flo matrix pump; K-2006C kit; 2 bottom drains. PF=6.7
