Thread: How much salt to add.
    Jun 2013
    Virginia
    Default How much salt to add.
    Been having heavy rains here and drained some of the 5000 gallon pool. I have a salt reading of 2230PPM. Question is how many pounds of salt do I need to add to get it back up to 3000PPM?
    Default Re: How much salt to add.
    Go up to the Forum Q & A section at the top of the main forum page. There is a thread called "bleach calculator" that is actually much more than a bleach calc. If you click on the drop down menu in the upper left-hand corner, there is also a salt calculator that you can use to figure out how much salt to add.
    Hope this helps.
    Jun 2013
    Virginia
    Thank you.
