Thread: Following "Super-simple" guide but have algae
    Aug 2012
    New York
    Default Re: Following "Super-simple" guide but have algae
    Thanks! I brought the chlorine up to ~12ppm this morning and this evening the pH is up around 8.0 (from 7.5). Is that normal?
    I think the pool was looking better, but it's night now and I can't tell. Chlorine is down to around 8ppm--I'll bring it back up to 12-15 for the overnight.
    18' round 7K gal Intex AG pool; tabs, hand fed granual; Game Sandpro 50 sand filter; Game Sandpro 50 pump (1/2 hp) pump; 24hrs; Taylor K2006; utility water; iPhone; PF:17
    Yes, the pH rises when you add chlorine bleach or chlorinating liquid, but it will drop back down when the chlorine gets used/consumed. Maintain the higher chlorine level until the pool clears.
