We are currently looking at buying an above ground pool. We would love to do inground, but the cost is what's stopping us. That being said, what is better - regular old fashioned chlorine or salt water? What are the pros and cons of each?
You've been scammed by the typical marketing for SWCGs -- Salt Water Chlorine Generators. A SWCG is just a *method* for adding chlorine to your pool, not an alternative to chlorine.
Several things to consider:
1. SWCG use voids the warranty on most metal wall AG pools.
2. SWCG's are very convenient, but are NOT cheaper than hand feeding chlorine, assuming you use the BBB method consistently.
3. Even with an SWCG, you will need to manually maintain chlorine levels during start-up, and during any sort of problem with algae, etc.
For pool owners who are away from home frequently, an SWCG can be a lifesaver. In most other situations, they may be nice to have, but definitely not essential.
PoolDoc / Ben
They can be convenient, without a doubt. But they get people in trouble, because they are sold as if you can turn them on and then forget about your pool's chemistry forever.
So does a SWCG take away the chlorine smell and red eyes? If so - that's the route I'm going! LOL!
Seriously - I understand about the chemistry and keeping it properly balanced. I'm just trying to find out what is the better route to go. I havent bought a pool yet and I am in the research stage. Right now I am leaning towards a resin pool, but I dont know whether to go steel or aluminum wall. Working 12 hour shifts with lots of down time can play hell on your mind when searching for info. There's just too many opinions out there!
A SWCG pool IS a chlorine pool so it shouldn't make a difference. Actually, you should not smell chlorine nor get red eyes from a properly maintained pool.
Thanks - now I have a better understanding. There's just SO much information to take in...
Yeah, it's a lot at the start.
