Thread: Anyone familiar with the Simple Salt setup by Simple Blue
    Jul 2013
    VA
    Default Re: Anyone familiar with the Simple Salt setup by Simple Blue
    At this point Im not sure what to do. Like I said Im new to the pool world. I originally wanted a salt system and was informed of a warranty issue if I was to do a salt setup.
    With that being said , I was at the mercy of the dealer to guide me in the right direction. Now to figure out what I need to do to rid myself of this system. Whats the best low maintenance way to go ? Salt or Chlorine ? Even though manufacturers warranty doesnt support salt, at this point Im open for the best route to go. Any recommendations would be greatly appreciated. Thanks
    BigDave's Avatar
    Salt is chlorine. Salt systems manufacture chlorine in your pool water directly.
    My opinion is this: The method of poolcare taught here is the safest, most efficient and effective you will find. Once you learn your pool's needs and how to meet them, this method takes only a few minutes a day plus occasional brushing / vacuuming (you'd need that any way). A salt system or any other system still requires daily monitoring - anything less and you'll spend a lot of time correcting big problems instead of a little time adjusting for measured needs of the pool.
