I can only guess, until you have CYA test results from the K2006 or the HTH 6-way (info on both on the SS recipe page), but for now if you get a cheap OTO / phenol red kit, a DARK yellow chlorine result should be OK -- that above what the test block will show, but around 5 - 10 ppm.
