Results 1 to 10 of 10
Thread: cyanuric acid test
    Default cyanuric acid test
    When using a drop based test kit to test for cyanuric acid is the reading correct when the black dot just starts to disappear or when it completely disappears? I am using a Taylor test kit.
    Frederick,Md
    Default Re: cyanuric acid test
    When reading this, my reading is different in shade or overhead sunlight which is more acurate.
    25000 IG gunite.
    Sunlight, at your waist.
    Frederick,Md
    Thanks Carl. It does make a difference.
    25000 IG gunite.
    actually, cya testing should be done by nothern light, not direct sunlight by everything that I have been able to find out about this test. I do it in the shade out of direct sun light but not in dark shade. (If you want to move this to the china shop it might be an intersting discussion.)
  1. No Cyanuric Acid?
    By Strongmad in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-28-2012, 12:21 PM
  2. Cyanuric Acid Test Reagent
    By Wobbly in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-21-2011, 04:45 PM
  3. Cyanuric Acid
    By Sue225 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-30-2010, 05:35 PM
  4. cyanuric acid
    By kickurasin in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2007, 12:23 PM
  5. Cyanuric Acid
    By golfwig in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-18-2006, 04:30 PM
