Thread: Test Results - I'm about to give up :(
    Swansboro, NC, USA.
    Exclamation Test Results - I'm about to give up :(
    I have an AG pool approx 8000gal. I opened it several weeks ago and treated it with the bbb method and it was perfect. It turned green and I treated it and its blue but VERY cloudy. Its been like this for alittle over a week. I've been shocking it up to the level using Bens best guess chart, scrubbing, etc...still nothing. When I brush it the water turns green again but not as green as it was and it doesn't last long. I also have had the filter running 24/7 for the past 2 weeks! I just purchased the Hayward automatic pool cleaner, diver dave. Dave is in there now working for me to try and get this pool clear! He was in there for approx 30 min and I noticed he wasn't moving anymore, I went out there and saw the pressure was low so I backwashed the filter and all the nasty junk came out which was ALOT. Mind you, I backwashed it just before I put Dave in there, so I hope this means that Dave is working!!! I had a few small leaves come out but nothing major as we have no trees around us. Here are my test results:
    CYA 60
    PH 7.6
    Chlorine 10-11
    Alk 200
    Any information, thoughts, suggestions, tips, tricks, etc. would be GREATLY appreciated! I was being so patient but I haven't seen results so I'm starting to give up. I need a kick in the rear!!
    TIA
    Default Re: Test Results - I'm about to give up :(
    Take your chlorine on up to 15ppm. Test 2-3x a day and each time, bring your chlorine level back up to 15. Try not to let the level fall. If you are still not seeing much progress after a few days, try shocking it up to 20 for a few day. Keep the pump running.
  1. Difference Between Liquid Chlorine and Household Bleach
    By sun and water in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-03-2012, 08:32 AM
  2. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  3. OK, I give up!
    By larry2338 in forum Pool Equipment & Operations
    Last Post: 06-26-2006, 10:35 AM
  4. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
