Dead algae can be hard to filter. The sand filters with AG pools can be especially bad for this, since they are often too small for the pumps, and the small particles get forced through the filter.
For now, do these things:
1. Get a cheap local OTO / phenol red kit (yellow / red drops)
2. Get 16 gallons of PLAIN 8.25% bleach
3. Remember (write down) these figures: 17,000 gallons; PF=7
4. Add 2 gallons of bleach this PM, and then 1 gallon every following PM, till we've worked out another plan.
5. If your pump has 2 speeds, turn it to low speed, but leave the filter on 24/7
6. If not, add more DE, and see if the DE shoots back into the pool via the returns (where the water returns to the pool)
7. Post test results (OTO), a list of ALL the chemicals you've used, and the results of the DE test.
