Where do I begin.... New owner of a terribly Neglected pool...
Hi all... New to your amazing forum... I've been lurking and reading a ton.
We've just bought a house with a pool through foreclosure. The pool has been empty and neglected for at least 5 yrs. The automatic cover tracks have pulled from the cement deck and the cover has ripped from the tracks. The pool itself is a 20 yr old gunite. It's got a few inches of algae and tadpole filled rainwater in the bottom. We have no idea of the condition of the pipes, pump, etc.
Where do we begin? We'd like to do as much as reasonable ourselves before calling in a pool company.
I'm assuming we should first remove as much of the water and algae by hand as possible. Then to clean it... Should we acid wash it or first hit it with a pressure washer? There are a few places at the bottom where the top layer of the smooth plaster is chipping off.
Then what?
Thanks in advance for all advice... I'll keep everyone posted on our progress..
-Teresa
