Results 1 to 10 of 15
Thread: I've used HTH algaecide - do I need to drain my pool?
    Aug 2013
    Dallas, TX
    Default I've used HTH algaecide - do I need to drain my pool?
    Hello,
    I'm new to the forum. I bought a house with a pool last year. After battling the pool chemistry for a year I enlisted help from a pool chemical service company (as I know how to clean out my cartridge filters, pump, and polaris 360, and skimmer baskets). I had been using HTH chlorine and algaecide yet I was still battling algae. After having him arrive for the first time this week he mentioned that the HTH algaecide is horrible for pool chemistry and recommended that I should drain my entire pool and start over. I'm looking for some recommendations to counter-act the negative affects of using their product.
    Thanks!
    Default Re: I've used HTH algaecide - do I need to drain my pool?
    I don't know of any algaecides that are so bad you need to drain your pool. If you'll give me the exact algaecide name, I can verify that.
    Do NOT drain your pool if it is vinyl or fiberglass; do NOT drain it if its concrete if the ground in your area is saturated with water from heavy rains.
    DO consider checking with another pool service -- I can't be sure, till you give me the exact algaecide name, but this sounds like a scam to run up the bill on a new customer, before dumping them. HTH currently makes products that I'd never recommend . . . but I'm pretty doubtful that you need to drain the pool.
    Aug 2013
    Dallas, TX
    Default
    It's HTH 3x concentrate Algae Guard. He mentioned that as a result of using it I had a lot of combined chlorine and no free chlorine. As a result he said that adding additional chlorine probably wouldn't be any use, also that it may take a month or so for my cloudy water to clear up.
    My pool is an in-ground plaster pool.
    Aug 2013
    Dallas, TX
    I tested my water this weekend at it's ammonia levels are at .5 PPM
    Assuming your ammonia test is valid, THEN
    1. Use borax to raise the pH to near 8.0.
    2. Add PLAIN 8.25% household bleach each evening at the rate of 1.5 gallons per 10K pool gallons. Continue until combined chlorine levels is less than 1 ppm. Postpone a dose anytime the free chlorine level is greater than 10 ppm
    3. Order a Taylor K2006 (test kit page with links to Amazon in my signature block -- these kits can NOT be purchased locally!) ASAP. Report test results ASAP.
    Aug 2013
    Dallas, TX
    I added 3 gallons of bleach and 2 pounds of shock my pool is ~50k gallons by my estimate. I ordered the kit and I will report back with the results.
    50K gallons is a HUGE residential pool, and very unusual. A 30 x 60 lap pool with 4' ends and a 5' center would be only 57K gallons; a 20 x 40 block wall pool with a 4' shallow end, 12' flat deep end, the break at 10' from the shallow end and a flat bottom straight wall deep end would be only about 45K gallons.
    Please measure the pool's dimensions. It's hard to dose correctly, with incorrect volume calculations -- but about 30% of pool owners use seriously incorrect values.
    Aug 2013
    Dallas, TX
    So, you're right. I re-did some rough calculations today. My pool is two heptagons (7 sided) joined by a rectangle (it's a custom made pool). It's apparently roughly 2100 square feet so it's roughly 15.5k gallons. Still waiting on my kit.
    Aug 2013
    Dallas, TX
    I got my K-2006 kit. FC - 0; pH- 7.4 ; TA - 90 PPM; Cyanuric Acid < 30 PPM
