Closed Thread
Thread: HTH Green to Blue- Removal??? Please don't use this!!!
    Default Re: HTH Green to Blue- Removal??? Please don't use this!!!
    I've done a bit of checking, and there are various reports of users being told by HTH / Arch customer service staff that the Green to Blue system is ONLY for inground pools with sand filters. But apparently, no such warning appears on the labels!
    The product consists of 2 parts: (2) units of cal hypo blended with magnesium sulfate + (1) unit of aluminum chloride (poly-aluminium chloride).
    The first part is just diluted cal hypo, and can be used in any pool where cal hypo can be used. Poly-aluminum chloride (PAC) is a different deal. It is apparently effective at settling dead algae, but becomes a nightmare for pool owners who have DE or cartridge filters, and no effective way to vacuum the settled dust.
    Apparently some HTH reps have been recommending draining!
    April, you CAN purchase a vacuum system to use in your pool, but you'll end up spending $100+ dollars to get what you need. If you're willing to go that route, I can give you links, and explain how to vacuum your pool to "waste", by setting up a siphon. There are some tricks that will help.
Closed Thread
