Re: Green Hair????
you posted copper/iron at 1.3 ppm. Which is it, copper, iron, or both? If either copper or iron is that high you need the keetrol or a similar product such as Jack's Magic Blue Stuff or ProTeam's Metal Magic. Before you use a product like this the bottle will tell you what your pH and chlorine levels need to be. Follow the directions and do this first! How many gallons is your pool. You said it was a 24' round. How deep? If you don't know the gallons then post the depth and we can calculate it for you. If you have a 4' water depth then the pool is about 13,500 gal. Then we can get you on your way to getting the water balanced!
