It may be difficult, but level means level. Having an area 'dish' in the center a few inches won't matter. But the sides are altogether different: level means level!
You have to keep in mind that your pool is a 'water level' -- that is the pool surface when still will be completely level to within a 1/16" (or 2 mm if you prefer). If your sides are out of level 2", the pool *might* work, but if your skimmer is on that side, keeping the water up into the skimmer throat is likely to mean it will slosh out on the low side!
Commercial gutter pools are supposed to be level within 1/16", regardless of size. I currently service a 200,000 gallon pool that is 4" out of level across a 90' distance, and it causes no end of problems that I have to dance around. Unfortunately, the original project engineers ignored the soil tests that indicated the pool need to be built on piers that extended 20' down to non-plastic soil. The customer had to spend $30,000+ in temporary repairs 4 years ago; they are planning to replace the pool in 2015 at a cost of $1,000,000+
