Results 1 to 10 of 152
Thread: Bromine Chemistry Question
    Default Re: Bromine Chemisty Question
    Let me clarify some things.
    1. Hardly anything is "out" with the BBB method. Carl's due credit for coming up with a convenient and easy-to-remember name for the approach to pool chemistry I've taught, but there are times I wish he'd thought of a different name. The problem is, it tends to fix people's minds too tightly on a limited set of chemicals. The fact is, I'm not against ANY chemical . . . used with a good reason.
    2. Polyquat allows you to keep your pool from going green, while the chlorine is low.
    3. When you've got metals in the water, you need to keep the chlorine low, to avoid 'dropping them out' and causing stains.
    4. But, EVENTUALLY, you have to do just that: the cal hypo is for the purpose of helping you 'drop them out' on the filter (and on the calcium particles on the filter, from the cal hypo.)
    Basically, what you're trying to do, is get your pool up and running smoothly via HEDP, polyquat, low-ish pH, and low-ish chlorine. Once you've done so, THEN you can switch to removing metals without staining things much, using gradually rising pH, gradually rising chlorine . . . and precipitation ONTO the filter, via cal hypo.
    Unfortunately, managing metals remains complicated. I haven't come up with, or seen, a simple method for doing so. We'd hoped this product would do so:
    1.5 ppm CuLator pack
    Poolmaster 16242 Poolmaster Skimmer Basket Liner
    We've been disappointed, because though it works, it works too slowly to be a one-step solution. It *is* useful as an ongoing preventative. If you get one, get the skimmer socks, too. These keep it from being quickly contaminated with 'pool goo'. CuLator says you should change these monthly -- and you should, if your goal is to improve CuLator's quarterly statement! Otherwise, you only need to change it when it's heavily discolored (from captured metals) OR gummed up with goo.
    Does this clear up any of your questions?
    Sorry! Too late for that, Ben! Too many years, too many people and sites have picked up on it....I wanted a catchy memory-jogger, not a rigid "This way or the highway" and didn't include acid or stabilizer in it...BBBAS (Bee-Bee-Bass) sounds weird and complicated.
    I, too, use what's right at the time--and sometimes what I've got in the shed so I don't have to go running.
    Metal-clearing seems to be THE most difficult aspect of pool chemistry, other than conversion from something to Chlorine.
    Jul 2013
    Northern Illinois
    I have a bunch of questions about all that but for now I need to get back to the TA issue...
    Here's what I did. I added 3/4G of MA, waited 4 hours, got a pH of 7.1ish and added 1 more quart of MA (and 3/4C of diclor). After an hour, I turned on my 2 fountains and the step swirling jets and then went to bed. In the morning my results were:
    pH 7.4
    FC 3.6
    CC 0.6
    TA 200, then 180, then 200
    CH 90
    I freaked out and took a sample into Leslie's.
    They agreed with the pH but they said TA was 150, yesterday afternoon they had 170 so they think the acid and aeration is working. But, I returned home to retest TA and I got 200 again. I don't know who is right or wrong on these numbers. I even purchased fresh TA reagents the other day because my numbers weren't agreeing. I will continue with lowering my TA per directions but I don't know which numbers to trust here. I'm thinking Leslie's as I had TA at 200 before the gallon of acid and I still have TA of 200 and the acid MUST have done something....!
    BigDave's Avatar
    When you do the TA test, are you swirling the sample after every drop? For me, when I'm getting close to the TA reading I see a red spot where a drop goes in that goes back to all green after swirl. Next couple drops the sample turns a silver / gray color after swirling. One or two more drops and the sample stays red.
    Jul 2013
    Northern Illinois
    Yes, and my color changes are the same as yours. If I run the test twice in a row, I have to admit the second time I add 5, swirl, add 5 swirl, add 5 swirl, then drop by drop. I just ran it again, drop by drop, and it is 200. Drat, I don't know what the problem is. I just tested the pH also, 1-1/2 hours after adding 3/4G MA, and it is down to 7.0. I will let MA circulate a half hour more and then aerate again. When pH comes up I will test TA again.
    I wouldn't focus too much on exactly what it is: every test agrees that it's somewhat too high. Just lower your pH to around 7.0, and maintain it there, till the TA is closer to 120. If you can't get a stable reading then, we can wrestle that problem, at that time.
    Remember:
    Vinyl pool
    pH 7.4
    CH 90
    T/A tests at 150, 180, or 200.
    Unless your pH is consistently trending upwards, it's just not that big a problem. Yeah, fixing is probably a good idea, but it's not going to cause your pool to go cloudy or scale metal, not with your CH so low.
    If CH was 400 or 500, or you had to keep add MA to control pH, then you'd have a problem.
