Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 152
Thread: Bromine Chemistry Question
    Jul 2013
    Northern Illinois
    Default Re: Bromine Chemisty Question
    Results:
    Home: No difference in TA after agitation. TA still 220-230 depending on how dark a pink-red I go for.
    In-The-Swim: TA 240 and he went dark like my 230
    Leslie's: First he used his reagents. TA 110, then mine TA 150. He stops when color is greyish.
    So, I will trust my reagents and just be frustrated that there has been no change in TA after 2 full cycles of MA.
    I think I may have figured out my problem, however. Even though I read the directions over and over.... I goofed and am feeling pretty embarrassed.
    Your instructions say:
    4.) Begin aerating.
    5.) Test your pH AND your alkalinity. Continue adding acid to MAINTAIN your low pH until your alkalinity reaches your target value. Once it does, continue aerating, but allow the pH to rise to the normal level.
    I have been getting my pH down to 7.0 and then aerating to bring it back up to 7.5/7.6 and then lowering it back to 7.0 and aerating back up to 7.5/7.6. I see that your instructions say MAINTAIN low pH. I am now going to keep it around 7.0. I will reduce the amount of aeration at least until I know the MA has completely circulated.
    Does that make sense? In the meantime, should I continue with 1C dichlor every night or switch to the calcium hypochlorite?
    I'm going to have to give you some different instructions.
    1. Test your pool's pH each evening. If it's above 7.2, add 1/2 gallon of MA. Make sure the pump runs for at least 4 hours after. Do NOT test TA or CH during these 3 days!!! Continue to aerate, using whatever approach you've chosen.
    2. After 3 evenings of testing pH and adding MA **as needed**, the following (fourth!) day test the TA.
    ==> If the TA is <150, do not add acid for 3 days. Do *NOT* test the TA again for 3 days. Discontinue acid additions during this period.
    ==> If the TA is > 150, recycle to #1 above.
    3. After waiting 3 days (after a TA reading < 150 ppm), retest both pH and TA, and report results here. Do NOT test either pH or TA during the 3 days you wait.
    OK?
    Under NO conditions should you ("BromineUser") test TA more than 2x per week.
    Jul 2013
    Northern Illinois
    I think I've got it.
    Maybe you'll have to add these instructions as an addendum to your original. I'm thinking "Lowering Swimming Pool Alkalinity ...FOR DUMMIES" Feeling pretty low and incompetent right now!
    In the meantime, I have been using 3/4-1C dichlor nightly. Do you recommend I use dichlor or the calcium hypochlorite (or a mixture) during these next many days?
    Let me try to simplify the T/A lowering procedure. We've batted this around for at least a half-dozen years until Chem_Geek untangled it so we all understood.
    1) T/A reading depends on the pH reading. So at 7.0 you'll get a lower T/A than at 7.8, when actually they are linked. If you raise pH with Borax or Soda Ash, T/A goes right back up.
    2) So you lower pH to, say, 7.0.
    3) Aeration RAISES pH! The fancy chemistry has something to do with breaking down carbonic acid in the water but the end result is aeration raises pH but does NOT raise T/A with it, unlike other ways to raise pH.
    4) You then lower the pH again, pulling down T/A with it, and aerate to raise pH without raising T/A again.
    In other words, you are ratcheting the T/A down. The aeration doesn't lower T/A (though if you keep pH constant at 7.0-7.2 it will SEEM that way). Lowering pH lowers T/A and aeration allows pH to rise without raising T/A.
    On another note, you keep wasting your chlorine reagents doing the 25ml test. Only do the 10ml test. We/you don't need to know that FC is 7.2 or 7.4, 7.0 or 7.5 is close enough. Same for CC.
    Jul 2013
    Northern Illinois
    So if I understand you, my lowering pH with MA to 7, raising by aeration to 7.6, lowering by MA to 7, raising by aeration to 7.6, etc., actually might have done something other than waste time and MA. I don't feel so stupid, if so. I think though that Ben is saying that I need to KEEP my pH low for an extended period and not to aerate with the goal of raising pH all the way back up to 7.6 or higher before adding more MA. I will follow his instructions to the letter as my ultimate goal is to have a great pool with no unneccesary chemicals, to keep money in my pocket and not the pool store's, and to become "FormerBromineUser"!!!
    Quote Originally Posted by BromineUser View Post
    It's not that at all. People are wired differently. A couple of years ago, my Assistant Scoutmaster was that way. We were accumulating more and more gear, but couldn't get permission from the church to build storage shelves and racks. So, the stuff piled up. It didn't bother me: they were somewhat organized piles, and the boys could not have cared less. But David is neat and organized by nature, and it drove him nuts. In truth, he was rather obsessive about it. But, that same nature had enabled him to pay meticulous attention to mind-numbing financial papers, with result that even though he was just over half my age, he could buy and sell me 10x over.
    There are times when it pays to be obsessive about pools, but this particular situation of yours isn't one of them.
    I think there's come a time to all of us when we say "D*** it all! I'm going to empty this pool and shut it down! No more!" Sometimes more than once......
    It reminds me of the cynical quip: "A boat is a hole in the water, surrounded by wood or fiberglass, into which you throw money!" With the follow-up being "The two happiest days in a boatowner's life is the day he buys the boat...and the day he sells it!"
    Jul 2013
    Northern Illinois
    Today I received my property tax bill (up over a thou to $15,000), got a voicemail from the pool installers saying I need a new heater ($2,800 -silly me, I was saving for an auto-cover pump), got a contract for the next school year with no raise for the 5th consecutive year, and my roof is leaking. I appreciate the life-story and the humor... Sell the dratted boat!
    Sounds like you should consider solar panels instead....
    Reminds me of the old story about farmer complaining about his barn roof leaking. The other man says "Why don't you fix it?"
    He answers: "I can't. It's raining."
    The other guy says: "So wait till it's not raining."
    The farmer answers: "It doesn't leak then!"
    (No criticism implied...just a stream of consciousness remembering.)
    Sounds like you need to move to Georgia! (Not including Atlanta! Atlanta is not Georgia; it's San Francisco East!) Not many people working for school boards have properties with tax rates like that. And, given how far under the water Illinois (esp. Chicago) is, it's likely to get worse before it gets better.
    Being in Georgia wouldn't help there: my wife (elementary teacher) is getting 'furloughed' 3 days next year, but that's an improvement for 5 this year, and 9 (I think) the year before.
    Dark pool covers make MUCH better temporary roof fixes, then blue tarps, if you are going to have to wait a few months.
