Thread: Are the stains from metal or algae?
    Jun 2013
    Delaware
    Default Are the stains from metal or algae?
    Stains are green, blotchy, smooth to the touch. I have super-chlorinated twice to 30 ppm and brushed. They were not there when I closed my pool last fall, but they were there this spring when I opened it. I assumed they were algae since the water was very green as usual. I used a Nature 2 last season but did not replace the cartridge this year after reading about it. What is the best way to tell if the stains might be from metal rather than algae?
    26,000 gallon plaster Oasis shape 40' x 18'. 54 sq. ft. vertical grid DE filter. 1 hp pump.
    Jun 2013
    Delaware
    Default Re: Are the stains from metal or algae?
    Thanks Watermom. I don't have any in the house, so I'll have to pick some up and try that. I don't suppose I can substitute an over 50 multivitamin, lol?
    BigDave's Avatar
    Yikes! No! You already suspect a metals problem - don't put "Silver" in.
    Jun 2013
    Delaware
    Haha Big Dave - thanks for the tip! OK, I tried the vitamin C tablet, rubbing on the same green spot until it was worn down to my fingers - didn't seem to have any affect.
    Jun 2013
    Delaware
    Just an end of summer followup to this thread. I maintained the pool water at 5 - 10 ppm FC and CYA at 60 and the stains gradually went away. I am assuming the stains were algae and just stubborn because they faded away in a few weeks and are now gone.
    Virginia
    Quote Originally Posted by tfrailey View Post
    Thanks for the follow up. It's mvery helpful to others who may have the same isue. Too many times people will post their problem but not follow up.
    Btw, I had something similar happen one time. Once I started adding CL it went away.
