Re: Cleaning pool after previous home owner
Consoleman,
I think Doc is suggesting the cheap OTO kit to tide you over until you get the K 2006. Based on your other threads, I suspect you already have it, in which case I'd use the K 2006 to do the tests. OTO is used by some as an "in between" K 2006 tests. You could probably use the 10ml sample size initially until you figure out what you have, but Doc may want more accurate tests using the 25 ml sample. In either case you only need 1 scoop of powder for the FC test.
