Re: unable to maintain chlorine levels
thanks so much for the very quick reply.
Just to be clear: I'm to shock with 3 gals of bleach every day until the chlorine level stabilizes for 24 hours. AND, if there is a zero or very low chlorine level after 24 hours, then I shock with 6 gals of bleach. Do I have that correct?
should I be worried about the bleach raising the pH too high at this point?
I ordered the K2006 but deliver won't be until next week. I will report my readings to you then.
Again, thank you for your unbiased advice and knowledge.
rectangular vinyl IG pool w/ board
