Results 11 to 15 of 15
Thread: 27K gallon pool with slippery sides
    Jul 2013
    NJ
    Default
    Sorry my pool is 40x23 27k gallons IG with a liner....so do I do 5 gallons of bleach? Thanks for the help I hope this takes care of it..
    I also have a SWCG.
    Default Re: 27K gallon pool with slippery sides
    Ah, yes. That's why we try to keep threads to one original poster. I just jumped to the start for your gallons, and found the OPs gallons rather than yours. I should have moved your posts to their own thread, but have done so, now.
    1. As you thought, instead of dosing for 5K with a PF of 20, you're dosing for 27K with a PF = ~4. Instead of 1 gallon per dose, you need 5.
    2. Turn off your SWCG till this is resolved. You're just burning it out, since it can't keep up. SWCGs work best when used ONLY when the pool is functioning well. Turn them off when you're cleaning a mess.
    3. Otherwise, the advice is unchanged.
    Jul 2013
    NJ
    Sorry about that... I added the 5 gallons of bleach tonight I'm looking forward to a crystal clear pool again soon. Thanks again for the help.
    Jul 2013
    NJ
    Hi PoolDoc,
    I never Thanked you for your help. My pool is crystal clear!! Thanks again for the help, counseling & guidance. I'm so happy I never had to add algaecide!!!!
