Results 1 to 8 of 8
Thread: Switch Sanitizers at Pool Closing or Opening
    Aug 2013
    PA
    Question Switch Sanitizers at Pool Closing or Opening
    I have been using Baguinide for 6 years now. While I have had OK success with it I am now getting to a point where I think I need to switch. Had some cloudiness issues this year even with pH and TA (along with H2O2 and sani) levels being good. I am also getting a bit tired of dealing with plugging up my cartridge filter way quicker than expected.
    Anyway, I was thinking that going through the process of switching to Chorine (or another alternative) when closing the pool would be less intrusive and much more certain than trying to do it when I open the pool next year. What I mean by that is I don't mind spending 2-4 weeks converting my pool to, say, chlorine after I know I am done with the pool for the year...ie being too cold here in PA. I understand that there would be less (if any?) biguanide in the pool in the spring but I also figured if I have converted in the fall then I know there is nothing I have to worry about in the spring. I would also, likely, just buy a new filter in the spring as well knowing that the previous one went through the conversion and a season of biguanide.
    Does anyone have any opinions, insights or recommendations on this thought? Put it this way, I would rather work a little harder this fall to ensure proper conversion than wait until spring but since I have never done this before I may have no idea what I am talking about.
    Thanks in advance!
    Default Re: Switch Sanitizers at Pool Closing or Opening
    The info on how to use -- or remove -- Baquacil (PHMB) is here:
    http://www.poolforum.com/pf2/showthread.php?179
    Plan on replacing your cartridge or sand. If you have a DE filter, and the grids are clean, you're in luck. Otherwise, you may need a new filter, or at least, a new set of grids and membranes.
    Aug 2013
    PA
    On second thought I may just drain the pool and replace my cartridge. Now I am either having an allergic reaction to a chemical (or something) in this pool. I have never had an issue until recent but I am getting a rash after swimming in the pool. Although I have had 10 other people in this pool including my daughter and nobody else is having the issue. It is only an 8,000 gallon pool I would imagine draining and refilling would be much easier.
    Hi, I have been using Baquacil (or the equivalent) for about 7 years now. I have had OK success with it but this year has been horrid. I had a clear pool for about 1 week and it was after I replaced, yet another, cartridge on my filter. I have 3 of them now in the past 1 1/2 years of our short eastern PA season. In the past 2 seasons it is rare that I have had a clear pool. I have actually had enough at this point and will be switching to chlorine. I actually may be draining my pool today and just replacing the cartridge and spraying everything down and refilling. I would seem that you also have a 8k-10k gallon pool. If you switch to chlorine, do your self a favor and just drain the pool.
    Aug 2013
    PA
    Default Converting an 8,000 gal Above Ground from Baqucil to chlorine -- should I drain or co
    With such a small pool is there any reason I should deal with converting or should I simply drain it and refill? I have never drained a pool before, is there anything I need to be concerned about when emptying an 18' round above ground pool? I saw some other posts discussing possible issues but they were all in-ground pools.
    BigDave's Avatar
    Default Re: Converting an 8,000 gal Above Ground from Baqucil to chlorine -- should I drain o
    The water is an essential part of the structure of an above ground pool. It's a pretty bad idea to drain it, definitely wouldn't want to leave it empty for any period of time.
    With a large enough plastic sheet you could drain and refill simultaneously, filling on one side of the membrane and draining from the other.
    I've seen reports that suggest that the residue from degraded PHMB accumulates and eventually becomes irritating. So, if you've used Baquacil for 7 years, you've very likely reached that point.
    There are a couple of things you need to consider.
    First, when you replace your cartridge, you'll want to be sure to get a Filbur or Unicel brand -- or OEM -- cartridge, and NOT a Pleatco or other Asian made replacement. If you'll post your exact filter make and model, I'll see if I can help you find a replacement. The online descriptions can be very tricky, since the people selling Pleatco, etc try very hard to present their products as 'just as good' but cheaper, and in the process, often use some very misleading descriptions.
    Second, as Dave noted, draining even an above ground can be risky. If you have a soft side pool (Intex, etc) it shouldn't be a problem. But with a steel wall pool, I would recommend leaving at least 6" of water in the pool. Unfortunately, if you do so, there will *STILL* be a bit of a conversion process.
    But, straight chlorine bleach should take care of it. Just use your OLD cartridge, while starting up, and switch to the new one once conversion is complete.
    Aug 2013
    PA
    To both BigDave and PoolDoc, before these replies I said "screw it"...I am draining it. So I did, I didn't have any issues as far as my one-time pool ownership expeirence person would know. I actually drained every last drop and used a rag to clean the whole interior of the pool. I am very anal about something like this considering I had so many issues. With that said the 8,000gal AG pool was drained and refilled all within a 24hr period. I have a propane heater that I only use under certain circumstances so I was able to raise the temp from 70F to 83F the next day. I got my chlorine levels up to 3 the day after filling and it has never been nor could it be clearer. Oh and it remained clear after adding the first 8oz dose of chlorine so I am pretty certain all the biguinide was removed from the liner and all other parts that were involved.
    As for the filter, against my better judgment and research I used the same filter I had been using with PHMB. It is a 120 sq/ft cartridge filter with a 1.5HP pump (yes I know crazy equipment for this size of pool but, hey, I got a good deal.) With that said I still had and have an unbelievably clear pool. I honestly feel like I have never had this clear of a pool after my first year (or second) when started PHMB. I researched my filter size to find Filbur or Unicel brands. I got to a point where I could not find either of those brands in my size filter need. The local pool store had a sale that ultimately provided me a Hydromatic (my filter brand) filter of BYOG, or a total price of $110 for two filters. Another local store had a Black Diamond (same filter I currently have) for $85. I decided on going the BYOG route since I would hope my filter replacement timeline would be much less than previously. I have literally had 3 filter cartridges in less than 2 full pool seasons here in western PA. Thanks to biguinide as I have a better understanding on how it works.
    Anyway, two questions from this:
    Why are you saying that you should not drain an AG pool? I mean it was empty before the installer filled it. One thing this helped me do was there were a couple of areas on the bottom of the pool (against the wall) that were "pits". I was able to rub the liner to an extent where I fixed those issues. They bugged the crap out of me...
    What is the difference between Unicel, Filbuer, Black Diamond and Pleatco filters? I was told that all of these mfgs (maybe not including Black Diamond) make filters with 3 levels of material so all three could, essentially, be equal. The Black Diamond was nice because there were less ribs but thicker material (essentiall providing the same square footage of filtration) but easier to clean. I have never used Unicel, Pleatco nor Filbur. I have only used the OEM (Hydromatic) filters.
    To end I have had a ridiculously clear pool since switching...I understand that there have only been a couple of times with people in the pool but we have also had some good rains. I was going to go the BBB route but with such a small pool and having had enough of dealing with my issues with PHMB I decided to just do straight chlorine. Figured with a good test kit and paying as much attention as I do to it I should be able to keep a good 2PPM chlorine level and 7.5 pH level. I'll see if I want to change to a slat water pool two seasons from now.
    BigDave's Avatar
    Congrats, glad it worked out.
    BBB is straight chlorine. BBB is a bit of a mis-nomer but the best name we have. What's really taught here is a safe, effective, and efficient method of pool care based on science and proved by experience. The method requires involvement: You test the water so you can trust the results. You decide what and how much to add to the water to keep it in range and you measure the results. You learn how your pool reacts to chemistry, swimmers, weather and you'll be ready to respond. Let's keep you new water clean, let us know how you're sanitizing now, and a full set of test results from a K-2006 (calcium probably doesn't matter much but it wouldn't hurt to get a baseline).
    Read the Best Guess Chart from Ben's sig - it explains alot.
    Did you order a K-2006 (or K-2006C) yet?
