The info on how to use -- or remove -- Baquacil (PHMB) is here:
http://www.poolforum.com/pf2/showthread.php?179
Plan on replacing your cartridge or sand. If you have a DE filter, and the grids are clean, you're in luck. Otherwise, you may need a new filter, or at least, a new set of grids and membranes.
