Thread: Leaking Liner on small pool
    Nov 2013
    Default Leaking Liner on small pool
    My 15 foot round pool has a leaking liner and I didn't really find out till I closed it for the winter. And the cover keeps sinking lower. My are my options.
    Nov 2013
    Default Re: Leaking Liner
    I actually would rather replace the liner. So I guess my question is if I drain it ( or let it drain on its own) will the sides hold up over winter, if not what can I do to keep that from happening.
    I don't have the experience with AG pool problems . . . OR the details about your pool, to be able to answer your question about the sides holding up. It might be wise, if you're going to replace the liner, let it drain, and shore up the sides, from the inside. You could do so fairly cheaply with some treated 2x4's, galvanized nails, and rebar stakes.
    Quote Originally Posted by popps View Post
    You can stake the verticals like you would a tent, even using tent pegs.
