Results 1 to 10 of 26
Thread: To drain or not to drain pool with high CYA?
    Oct 2013
    Default To drain or not to drain pool with high CYA?
    Hi there. New to this forum and have a question...I drained my pool a few months back because of high CYA but apparently didn't take enough water out since it is too high once again, (about 200).
    My question is...should I drain it now and keep it up over the winter, or just let it go green and drain it come springtime, and start over?
    Any and all responses are greatly appreciated...thanks.
    Default Re: To drain or not to drain?
    What size pool? What type? (Concrete, vinyl)
    You probably do NOT want to let it go green -- the high CYA will probably be biodegraded to ammonia. It may subsequently be converted to nitrates or nitrogen gas, but if it stays as ammonia, you will have a horrendous spring start-up problem.
    Oct 2013
    Thanks Ben. I filled in all my pool info but it is not showing up for some reason?
    It is a concrete 27K gal in-ground pool.
    It is already turning green since I've ignored it for the past week, (since pool season is over). Do you think I should drain it now rather than wait? I was told to wait because the CYA may go down over the winter and therefore I would not have to drain as much? If I did drain it now, how much should I take out...all of it or no?
    Thanks!
    Read the Best Guess page, linked in my blue signature block -- you *can* operate the pool with high CYA.
    If you're going to let the pool go green, I'd wait till spring to drain and refill. The reason is, if you end up with ammonia in the water in spring, you'll probably want to drain 100% -- but there's no way we've found to determine exactly what the bacteria will do in YOUR pool, so right now it's just a crap-shoot whether you end up with CYA => nitrogen gas OR CYA => nitrates OR CYA => ammonia.
    If you don't want to risk it (and algae stains, etc) by abandoning the pool for 6 months, you need to clean things up NOW -- use plain household bleach in 10 gallon doses till you read an OTO 'orange' level. AND . . . order a K2006 kit so we can get accurate test results, and work out a 'next' step.
    Oct 2013
    Ok, draining it now but I only have a small pump so may take a couple days. Is there anything I should be doing while it's draining? (i.e.. sweeping sides/bottom, etc)
    Thanks Ben.
    Yeah, what you said.
    You don't want stains or algae to dry on the sides. Using a hose with a nozzle is probably the easiest solution.
