Results 1 to 8 of 8
Thread: Cleaning pool after previous home owner
    Default Re: Cleaning pool after previous home owner
    Quote Originally Posted by nefretrameses View Post
    I think Doc is suggesting the cheap OTO kit to tide you over until you get the K 2006.
    Correct.
    In either case you only need 1 scoop of powder for the FC test.
    *IF* one scoop produces the pink color. If there's no color, 2 scoops may be needed to verify that the chlorine level is really zero. Sometimes, when the chlorine is very high, 1 scoop won't produce a sustained pink color.
    Oct 2013
    Houston, TX
    Ok, got it! I didnt understand why an expensive kit would not come with a PH tester.
    In-ground gunite 17,600 Gal, Nautilus FNS 36 DE Filter
    The K-2006 DOES have a pH test in it but it does NOT have the OTO type of chlorine test in it. That is the reason that Ben is suggesting that you buy an OTO/pH kit. For the OTO part.
