Re: *** Hayward Chlorine Feeder Help ***
Hi and welcome, but I don't know anything really about installing that kind of chlorine feeder. Realize that you use it to add Tri-chlor tablets, which add lots of acid and lots of stabilizer. If you test and monitor your water so you watch your pH daily and your stabilizer (CYA) weekly, switching to other chlorine, like bleach or cal-hypo chlorine, when the CYA level reaches the level you want. Di-Chlor powder adds even MORE stabilizer than Tri-Chlor. NEVER put anything in your Hayward Chlorine Feeder but tri-chlor tablets--very dangerous to put any other chlorine type in it. But in the water itself, chlorine is chlorine.
You'll want to get a proper test kit and we recommend the Taylor K-2006 or K-2006C test kits. I think PoolDoc and Watermom still have links to sources for them on their signatures. Also a good OTO test kit for daily test is highly recommended.
Finally read here about how to use the B-B-B method (Bleach, Borax and Baking Soda) with your new pool so it is a joy and pleasure and not a pain in the neck.
As for the plumbing...someone else should be able to help you.
