Thread: Is chemical balance importance in winter or off-season?
    Default Is chemical balance importance in winter or off-season?
    Hi,
    I live in phoenix and use the BBB method. In the winter we don't use the pool so I check the values less often. Is it as important to keep PH and TA religiously accurate in the winter when you don't use the pool, or can I be a bit more lazy with it?
    Thanks,
    Matz
    Default Re: Is chemical balance importance in winter or off-season?
    Thank you.
    Matz
    Aug 2013
    AZ Desert
    What about chlorine during winter...?
    (1997) 21.3k gal. IG, Sta-Rite Sys 3 600sq ft Filter, AO Smith 2.2hp single speed motor, in-floor jets. K-2006 FAS-DPD kit
    How cold does it get there? And how long does it stay cold? If your water is below 60 deg, or, better, below 50 or even freezing during most or all of your closed season, shocking before you close should be enough.
    I'm in NJ and once I close my pool I peek under the cover about once a month and usually, there's nothing to see. The water will either be clear or frozen, and that's fine. If you have ice on top of the water, algae's probably not growing underneath the ice. Too cold.
    Aug 2013
    AZ Desert
    We're in the Salt River Valley of AZ, east of Phoenix. Pool temp is 58 now. Don't use a cover, and just check pH & add a gallon of chlorine every week or so during winter. I have a fairly high CYA (160) so not too much drift. I've heard a rule of thumb for summer to run filter pump 1 hour for every 10 degrees of high temp...if this is somewhat accurate for summer, does it apply for winter too? I think I'm set to run 10pm to 4am now...is this overkill?
    Thanks, KC
    I cannot answer you because we are SO much colder here that filter and pump need to be removed and drained and pipes either drained or filled with antifreeze. So clearly there's no filtering during the winter.
