Water is now crystal clear!
I'll now start working on gradually bringing my TA down, and keep an eye on my filter pressure.
Thanks again, everyone
Be careful if your using Iron or metal heavy well water to fill the pool. You may have staining that occurs if your metals drop out of solution. I would pretest your well water for metals and if necessary filter out the metals before they get into your pool water.
33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
Aqualuminator with Fountain -- Solar Pool Lights
Pool Pictures at the link below
http://community.webshots.com/album/548241672nKeuyR
Matt,
Good work.![]()
This thread could be required reading for everyone who posts to this forum with cloudy and/or green water.
The issue always seems more complex than it really is.....usually because folks don't understand that the methodology is very important.
The overwhelming answer to get good looking water is.....Chlorine. But it must be applied in an organized manner with frequent testing and diligence.
Reread your first post, Matt. You did well to stop throwing all those "magic bullets" at your pool.....your results probably would never have been very satisfactory........not 'til you decided to apply chlorine using the correct methods.![]()
After posting about our gradual recovery from algae, haze & chemicals, I'm fine-tuning based on the tips here! If I'd caught this thread, I wouldn't have needed to postOriginally Posted by duraleigh
Thanks to all & Congrats Matt.
OK, now I see... my water too is cloudy, a light greenish cloudy but the green is coming from the "blue shock" stuff.
I have an above ground 24x24, if I remember correctly its around 13,000 gallons of H20. Should I get my FC (free chlorine?) up to 20 also? Just keep adding the bleach until I get to 20 (if thats the reply that I get) until the H20 gets clear?
Thanks in advance!!
Kim
Yes to cl level at 20 until it clears. I don't know what "blue shock" stuff is, but just stick with bleach. It won't cause cloudy water problems. Run the pump 24/7 also.
thanks WaterMom, we leave our pump running 24-7 all the time, don't most people? What would the purpose be for not running it?
Thanks so much, I am bringing home bleach TOMORROW!!!
Edit: I originally responded to gwrace1's great suggestion on testing/filtering my well water, but see that there is a forum area ( Stains & Metal Matters: Iron, Copper, Silver & More) meant for this topic. I'll read up there. Thanks, gwrace1 for the tip.
