Unless you want to uncover the pool and find the leak -- which probably will involve getting IN the pool -- I'm not sure there's much you can do except to continue to fill as needed. You cannot install a vinyl liner in cold weather, so that's not really an option. Even installing a patch would be tough. Local vinyl pool companies would have more experience trying to work with vinyl pools in cold weather than I do, so asking them might be helpful.
Welcome to the forum.
) -- there's little you can do usefully.
