Results 1 to 10 of 14
Thread: calculation for borax
    Katy, TX
    Default Re: calculation for borax
    Exactly. That's also why the calc is currently set to only adjust pH in 0.2 increments right now...it doesn't allow for alk. Within 0.2, the alk won't affect it too much. Still a good idea to go slow (as with any chemical addition).
    Michael
    BW-poolmom Guest
    Ok I am not getting it. Sorry.
    I have the bleach calculator. Where do I find how to use it for Borax?
    What is a sticky?
    Sorry to be so slow.
    FYI here are my numbers
    FC zero
    CC zero
    (I really shocked it 15+ before we left for a week It was still covered with pump running and it bottomed out before we got back)
    Alk 110
    pH 7.2
    Cya 30
    CA 150
    I have a 17 x 33 above ground ( I think it is 18,000 gallons?)
    Thanks,
    Beth
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    The BleachCalc does not do calculations for Borax to raise pH.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    BW-poolmom Guest
    alrighty then.
    I guess I need the chemical calulator that I saw mentioned in other posts. (been digging around some more).
    None of the links I find are working. Not sure what the problem is...
    Beth
    Don't know what is going on with the calc links, but if you will post your pool's volume and what chemical you need to adjust, someone who has the calc downloaded can help you figure out a dose.
    Katy, TX
    Quote Originally Posted by Watermom
    I goofed up with the way I entered the links in my sig. It worked the first time, but when I changed it, everything got goof up. It's fixed now.
    Michael
    BW-poolmom Guest
    Reposted from above.
    How much borax do I add to bring the pH up a little (.2 or.3)
    Thanks,
    Beth
    FC zero
    CC zero
    Alk 110
    pH 7.2
    Cya 30
    CA 150
    Thanks,
    Beth
    BW-poolmom Guest
    Nevermind.
    Just caught up on the thread. I will be happy with my 7.2 pH I guess.
    Thanks,
    Beth
    FYI I was shocking with liquid bleach. Our water (well) is very acidic here so when I top off the pool it is what it is...
    Quote Originally Posted by BW-poolmom
    What is a sticky?
    FC zero
    CC zero
    Alk 110
    pH 7.2
    Cya 30
    CA 150
    Thanks,
    Beth
    There is not a calculation for how much Borax to add--re-read my above post about other variables affecting it. Your pH is fine at 7.2. If you're using trichlor or dichlor to shock, then stop using it, because that's what is driving your pH down. If you're using something else, just aerate your water and your pH will rise. Unless your pH is falling, and you're NOT using trichlor or dichlor and have to explanation for the drop, I wouldn't worry about the Borax for now.
