Re: 2 Speed Filter Motor
In the US, hot wires are colored Red Black and Blue. In some areas, blue is common for an alternate hot wire. Three hot wires most likely means a 230v 2 speed motor. But the terminal connections I mentioned above I know are correct as I have 2-speed motor with the same labeled terminals.
http://www.engineeringtoolbox.com/po...es-d_1687.html
