One method that's been used successfully is to put a coupling or other fitting on the pipe at the point where it's embedded in the shell, and then grout around it with a high strength, low shrink concrete mix like Thorite (http://www.thoroproducts.com/pdf_appl/appl_thorite.pdf)
I'm sure there are many other methods that would work.
