Thread: issue with Compool CVA-24 actuator not stop rotating
    Feb 2014
    Florida
    Default issue with Compool CVA-24 actuator not stop rotating
    I have a 180 degree CVA-24 actuator going into the spa. When I turn on the spa the valve continues to rotate non stop. Eventually the spa drains out. I think it's suppose to stop once it switches to the spa mode. Any suggestion before I buy a brand new actuator
    Default Re: issue with Compool CVA-24 actuator not stop rotating
    Sorry you didn't get an answer -- getting good answers on very specific equipment questions is tough any time, unless it happens to be equipment someone on the PF Support Team users, but winter traffic is very low on the forum. PoolForum's focus is primarily on water chemistry and treatment, as well as primary equipment (pumps, filters & pipes).
    I've upgraded your membership, so you have increased forum access during the coming pool season.
    Good luck!
